Manufacturer: Bosch
Model Number: B20CS30SNS/04
Hi there. Im working with B20CS30SNS/04 and got error message eR CE, all manuals I found here on appliantology is for B20CS30SNS/01 and there no error like that there. Looking to find that service manual for that particular model. Any help highly appreciated. Thanks
These are the docs that Bosch indexes for your model -- same as for /01. So this seems to indicate that that's an undocumented error code. If you're absolutely certain that eR CE was the code being displayed, then that would indicate a bad board.
  • 2 weeks later...
So we tried to call bosch and no help. Found somewhere outside appliantology what that issue means miscommunication between main board and UI boards. Checked wiring - is good, replaced main board - didn’t help. Then replaced UI and problem was solved.
And yes error was eR CE - attaching pic to this post
