Had a newer GE front load washing machine that wouldn’t fill with cold water and found an exploded roach on the control board causing a ton of error codes. Replaced the control board and it’s fixed the cold valve problem but now the cycle selection will skip over normal wash. And maybe one other cycle. So the knob is not able to select all cycles. I’ll try to get the model number from the customer and update it below when I can. Any simple fixes that anybody is aware of for this issue would be greatly appreciated!88994A63-4176-4FBA-A061-CA457D553D1B.thumb.jpeg.69d56a7426cd6f771bf01482bc0b64d7.jpeg
  • Replies 1
  • BaineB254
Posted Images
Model # is GFW550SPN1DG
