frigidaire gcfg3060bf error 45
Go to solution Solved by jkiym,
after 5 or 10 min of running the oven, error 45 pops up. I can turn it off and on and it'll run for another 5 or 10 min. I also wouldn't mind a repair manual if anyone has it.
  • jkiym
  • vee8power
Posted Images
Do you mean there is a fan running? Error F45 is the oven control sensing that the cooling fan isn't running correctly. This could either the fan itself, the tachometer, or the control board. We're talking about the cooling fan under the cooktop, not the convection fan you can see in the back of the oven. The tech sheet should be taped to the back of the appliance.
  • Solution
I'm pretty sure the fan i hear running is the convection fan. I didn't know there was a cooling fan. I wasn't sure if "error 45" was the same as F45. Is there a way to test to see which one of those is the problem? Thanks for the reply!
I found the wires to the tach were lose. thanks for help!
