Idler Pulley not returning to correct position after replacing wheel on Maytag dryer LDE8000ACW
Go to solution Solved by Budget Appliance Repair,
I'm the original owner of this 30 year old Maytag dryer. I replaced the wheel this weekend on the idler pulley (it would squeak during the first few minutes of dryer use).
It went without a hitch until the end...the idler pulley won't return to its normal position after I threaded the belt back in. As a result the belt rubs against the metal edge of the pulIey and rubs against itself on the smaller wheel. I also tried spinning the drum like the guy in this linked video...for an example, the pulley should look like the video at the 6:58 mark, but instead it still looks like the 6:53 mark of the video. I'm also including a link below the video to high-res pics I took of my unit...maybe someone can see what I did wrong: Book1.xlsx
  • Solution
@Slugbait Most likely have the belt around the drum in the groove of the drum.  Belt needs to have flat/UN-ribbed surface around the drum and just forward, (towards front of dryer), in front of rear drum groove.
  • Like 3
  • 2 weeks later...
Yup, that was it. The belt slipped into that groove when I started the replacement, I thought the groove was where the belt was SUPPOSED to be (made sense to me). Now the assembly is right where it's supposed to be, thanks!
