Whirlpool electric range WFE320M0EW0 - a burner immediately shut offs
Issue with Whirlpool electric range “WFE320M0EW0” a burner shuts offs after being on for 10 sec and then keeps cycling turning on for 1 sec and then 5 sec off.
Eventually not heating the surface.
i changed the switch it didn’t work.
  • Nathaniel Peterson
  • Amitava
On 6/27/2024 at 8:18 PM, Amitava said:
Added video of the problem
IMG_1423.mov
Buy a infrared thermometer at harbor freight and aim it at the burner. I believe the thermostat on the burner cuts out the burner at 1600 degrees to keep the glass from melting. Make sure you got the correct infinite switch for that burner.
WP3149400 should be this one or 3148954
