GE PWE23KSKKSS stopped working after power outage
Hi Everyone
     Had a brief power outage today and when power was restored the refrigerator didn't turn back on.  Display inside is working   lights are on .  but the compressor isn't coming on. fan is not on either. When I plug it in a hear the clicks & the metering valve turning but not compressor
      The control board in the back has the green light blinking.
Is there a reset button? I didn't unplug for 15 mins but still nothing
Any advice would be appreciated
Thank you
Bubba
  • bubba153
  • Nathaniel Peterson
20 hours ago, bubba153 said:
Hi Everyone
Thank you
Bubba
Check the main board for damage. Most likely the board is bad but you'd have to check with a meter. If it's an inverter compressor you can check YouTube for checking that with a meter. Could check power to evaporator fan since that should be running. Make sure the control board isn't off too.
  • 4 weeks later...
Hi Nathaniel
     It was the Board. I always keep a spare board so that was the first thing a changed out and instantly the compressor started up
Thank you for the suggestion   really appreciate it
1 hour ago, bubba153 said:
Hi Nathaniel
You're welcome, good to hear.
