Manufacturer: LG
Type of Appliance: LaundryCenter
Model Number: WKE100HWA
Dryer has no power
You should be able to use this one:
  • Like 2
Thank you Captain!
This is the wrong manual. The key dance and error codes do not match this unit.
I had no idea where to read the flashing led. None are visible on the outside console.
Entering diagnostic mode is nothing more then ridiculous. All that was left out were 5 jumping jacks 😂
I just looked at one of these today. This manual says to enter washer load test mode by pressing "extra rinse" and "soil", that did not work. I got it into service mode by pressing "soil" and "temp". It then proceeded all the way through the different spin speed tests but gave me a 9E1 error (which is not listed in this manual) before proceeding to the fill valve tests.
The dryer key dance may be the same as on other models but this is 100% for certain the wrong manual and I can't troubleshoot this overfilling complaint without isolating the valves in diagnostic mode.
Edited by David1
Looks like the other service manual son of samurai posted says to enter the diagnostic the same way as the manual I posted.Go figure.
