discontinued T-stat for tappan oven
Surfside1
Help I have researched this part and found that is nla tried everywhere any suggestions any parts places that carry or specialize is discontinued parts...or can you find another tsat that would fit.  The customer is doing the job himself can't be something too complicated. Thanking you in advance for your quick response
  • Replies 4
I do not have nomenclature for Tappan models so I do not know what type of control it is.  Usually controls are made by either Robertshaw or HarperWyman.  If the control is brought into a appliance parts store, they should be able to match it up if it is a gas tstat, or a low end electric.  High end electric with self clean and bake and broil contacts you might have to go original.
Since repair clinic says it's NLA and have no source for it I don't guess I'll get in trouble.  I googled your T-Stat by the # given.  A-1 appliance parts show it available and in stock for $81.67.  Their # is 1-800-841-0312.........hope this helps
called the # you gave they said they do not have the part or a bin for it....any other suggestions?
The only thing I could suggest would be like T.T.H. said try taking it into an appliance store to try and match it up.....good luck
