Bosch B21CL81SNS/04 Freezer DEFROST
Robert Couchman
This French door freezer/fridge is six or seven years old. Recently it stopped making icecubes instead adding water to the ice cube tray creating a frozen mess. I assumed it was the ice cube maker(wrong), ordered a replacement, in the meantime the compressor started running nearly continuously. I cleaned the coils, removes the plastic coves over both fridge and freezer evaporator coils. Fridge was fine but freezer coils were packed in ice. Since I couldn't find a method for testing the defrost thermostat, I ordered one and after the manual defrost was completed, closed things up. When the part arrived, I again removed the plastic freezer baffle and although  nearly a week had passed, there was no ice on the coils.
I welcome your thoughts.
  • Replies 6
  • Robert Couchman
    5
  • Jack UvAllTrades
Jack UvAllTrades
Sure seems like your defrost thermostat was bad. If it failed in the state where it signaled that the freezer temp was over the limit, it would not allow the defrost heater to come on, which would cause a buildup of ice. Most of them will turn the heating element off at X degrees (where X is generally between 40° and 60°). They don't reset themselves until the freezer is below Y degrees (again, varies by model, but it just ensures that your system is working well again before it resets).
Your ice cubes were a mess because your coils were frozen over, blocking airflow thru the freezer and not allowing it to cool. My issue was nearly the same, but it was a bad timer that didn't advance to defrost mode. Yours advanced, but the sensor failed. Bet if you had ice cream in there, that it was really really soft/melted.
Robert Couchman
Thanks, very interesting reply, here's my dilemma, I have a new defrost thermostat which I have not installed yet because, first of all I don't have a strategy for testing to confirm the part is faulty and second because after running the fridge for a week following the manual defrost, the evaporator coils were not frosted up. I am assuming that if the defrost thermostat had failed, there would be significant frost build up over that period of time.
Your thoughts?
Jack UvAllTrades
Oh, I thought you replaced the defrost thermostat and that fixed it. If it hasn't iced up since and you haven't replaced anything, the original problem could have been a one-off. If the freezer door wasn't closed tightly for a while (like even overnight), it could easily have easily let enough moisture in to freeze over the coils, which would have caused the ice cube mess. The normal defrost cycle wasn't enough to overcome a system that was frozen over, so it couldn't ever catch up. I know when ours freezes, it takes a while to get it cleared even with everything off and a heat gun.
It also could have been food blocking the airflow and that got straightened out when you cleaned the system.
Our basement non frost-free freezer has had the door cracked open a couple times, not much, just a crack, but it's enough that we have to empty it all out to remove all the frost buildup that happens because of it.
Robert Couchman
Thanks for the thoughtful, lengthy reply! I really appreciate the effort you put into it:)
  • 10 months later...
Robert Couchman
The problem keeps recurring, soft ice cream, no ice cubes, etc. I did a manual defrost, pulled the heater sensor pigtail, the black cylinder (thermistor?) measures aroune 2K ohms at room temperatur, the othe device is open at room temp, heater shows 53 ohms, what do you suggest?
Robert Couchman
LolSo here's an update, I was able to do some research and cool the bi-metal to about 0° still measures open circuit. I ordered a replacement. In what may have been naive attempt to keep the fridge section and the food in it. Cool. I replaced the freezer drawers and plugged the unit back in. I had the steel cover off of the back side which covers the control board and another  board, when I plugged it in there was some arcing in this secondary board. I immediately unplugged it. I don't see any burn traces or obviously damaged components but now I am really fluxed. Appreciate any help you can provide.
