Manufacturer: Samsung
Type of Appliance: refrigerator
Model Number: RF22R7351SG/AA
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
I have the service manual.
I also have the Asurion June 2019 ice maker service bulletin and training manual with all the different model#s and the kits each need.
This fridge was built shortly after this bulletin, so the model # isnt on it, but they have "the" problem. But if i order all the different parts, ice maker, y clip kit, drain, control board separately, thats gonna be crazy.
Is there a new updated bulletin newer than June 2019?
Most of the newer ones already have the kit in it.  I always check by just opening the mouth of the ice maker and shining a light on it to check for the y clips.  if they are there then no need to install all those parts. may just need to seal the ice room
  • 6 months later...
I have this same model with a beard, you ever find anything for this model?
Nothing on bearded appliances, only shaven ones.
i believe the cutoff date is June 2019, before: needs the kit, after: just needs the ice room sealed because everything else is SUPPOSED to be done
