Click here to take the quiz.
Roper Refrig. Model #: RT18AKXKQ09
Tarheel Technician
Was wondering if anyone had the tech sheet for a Roper refrigerator model #: RT18AKXKQ09. This particular refrigerator must have eaten the tech sheet/wiring diagram, as it is nowhere to be found on the unit. I looked up on www.servicematters.com and could not find it there either. However, I did find the tech sheet for a RT18AKXKQ07.
Thanks.
  • Replies 1
You can usually use the same wiring diagram from the same model family if you take into account any functional or feature difference between that model and yours, e.g., dispenser, fan motor wattage, damper control, etc.  If you're looking at common things like the defrost circuit, it's almost always the same.
