Speed Queen Washer wont advance to rinse AWN412SP111TW01
Go to solution Solved by proton,
You guys helped me with a Speed Queen Dryer and I really appreciated it.
Now I have a problem with the washer.
I bought both of them used because they are going in my office and my wife wanted the exact thing in the office she has at home.
Here is the problem.
 I put it in and it worked fine.
I let it soak overnight with OxiClean and let it finish the cycle and everything worked.
I ran it about 5 times testing it and adjusting the water level.
 Now when it hits the rinse cycle the Timer stops.
It won’t do the Rinse Cycle on any of the settings on the timer.
If you continue advancing it manually it will go into the spin cycle, but it will not fill to rinse on any of the Timer options.
It fills fine, goes through the wash cycle and draining fine,  but it will not fill to Rinse under any circumstances in spite of the fact it worked until just now.
 Yes, I know it is probably the Timer but it makes no sense that none of the settings ( Regular, Perm Press, Delicate) on it will Rinse, even it you set it manually.
I admit I don’t fully understand how it works but I do know it is a simple mechanical timer that has a series of contacts it runs through to complete a cycle. I could see it not filling to Rinse on one of the options ( bad contacts) but it will not fill to rinse on any of the options.
 Sorry for being wordy but you guys understand these machines better than I do.
So simply, could it be anything else but the Timer?
And does it make sense that it will not Rinse on any of the washing options on the timer?
  • proton
    4
I hope that made sense.
Simply, the Timer runs until it gets to Rinse and then it stops and won't go any further. If you advance it by hand it still won't do the Rinse cycle but if you keep going it will start the Spin cycle.
But under none of the options will it go into the Rinse Fill cycle.
Even if you put it there manually.
I just tried the Permanent Press Cycle and it does exactly the same thing. It fills, goes through the wash cycle, drains, and stops and will not go further and advancing it one click at a time won't make it go to Rinse on that option either.
I hope this makes sense because it makes no sense to me. I did adjust the water level with the Pressure Switch before it started doing this but I can't see how that would make the timer stop.
  • Solution
I found the problem.
When I adjusted the water height Pressure Switch I inadvertently pulled a wire loose on the Water Temp Adjustment.
I am very sorry I bothered you guys with a problem I created myself.
