Service bulletin needed: Samsung Dishwasher Leaking out of diverter assembly
Manufacturer: Samsung
Type of Appliance: Dishwasher
Model Number: DW80K7050US
This 5 year old dishwasher has an LC leak error and it's leaking right out of the diverter outer o-ring. But there's three o-rings in there and they all need to be replaced cuz they're all rubber and they expand and start leaking If you take it apart. I tried changing just the outer diverter o-ring but the inner orings are leaked after repair. This is a bad design. Has Samsung redesigned this dishwasher to fix the diverter leaking problem that they created with their bad design? I need the service bulletin if there is one, please.
Edited by Ananda
  • Ananda
  • TheHelicopterKid
I found this info; not sure how helpful it might be however:
  • Like 2
That's interesting. Is that a service bulletin?
The problem with this design is they're using very short thread screws that are normally used in metal instead of the Long blade threads found in Whirlpool dishwashers that go into plastic. The thread strip out easily if you try to tighten them and then you have to replace them with long blade threaded plastic screws to get the compression you need to make it seal right. I had to replace two of the original screws because their threads were way too thin and they ripped out the plastic threads. Here's a huge red flag: Samsung discontinued selling the sump assembly indicating they realize the faults in their design and no willingness to fix this design problem.20241001_122318.thumb.jpg.afc4b2dcd0ad3920130adee73e1a48f7.jpg
Edited by Ananda
