Kenmore 111.75035020. Where is the airflow duct going to refrigerator from evaporator?
Go to solution Solved by Vance R,
Hi,
Above model has no damper. The R-fan is working freezer is also working. but no airflow coming to refrigerator. However i don't see any ducts originating from the evaporator area. I don't understand how the air from evaporator is going to the refrigerator?.Original problem was icing of the evaporator, The R-fan was not working , I replaced with an amazon brand as shown in picture. The icing problem went away freezer is working fine now  but no airflow to the refrigerator . food getting bad in couple of weeks was also an initial problem so i believe that that i had two issues to start with
Please help me in finding air duct path from evaporator area
Jacob
  • Solution
There is no damper for the refrig section, there is one for the pantry drawer.  They just cycle the fan on and off to control air flow. In the first picture the air goes up through the grates. Then goes central panel in the frig section. Check for frost build up in the duct and in the ceiling of the freezer.
Edited by Vance R
add last sentence
Thank you @Vance  R , I found the duct inside cup inside the first picture. Thank you very much
