GE GTD42EASJ2WW failure help! 🥺
Wildfire Phoenix
I have a GE GTD42EASJ2WW that I've been trying to repair since it completely quit mid load about a week and a half ago...
Damage so far has been the heating element, the hi limit thermal sensor on the right and the 4,500 ohm resistor (resistor broke from repeated disassembly) and a busted push button for the start switch (which I had not even realized was a problem to begin with 😱😱)
I have replaced the heating element, hi likit thermal sensor, currently waiting on arrival of the new 4,500 ohm resistor. Also replaced the start button and it's switch just for measures
Before the resistor broke, I tried starting up my dryer, but the drum light and door switch appeared to be the only things working on it.   🥺🥺
I've checked the dash knobs with my multi meter and all the dash knobs show signs of life and being ready to run.
Now my question is what the hell else on my dryer blew out, when it's heating element and hi limit thermal sensor grenaded on that last load?
I've already done a sweep on the exhaust end and there's no blockages there's at all.  I have already checked the door switch and that's not an issue.   Start button for the start switch is not the issue cause that was also replaced.
What parts could I have possibly missed which are the problematic end where replacing is needed?
Any help is needed ASAP please and thank you!
If I can not fix this ge dryer very soon it's getting junked & it's gonna cost me a minimum of $450 to get a new dryer which is what I'm really trying to avoid doing (especially after all the auto repairs I've had to make in the last few months when the hell did car parts get so dam expensive ☠️☠️☠️☠️☠️)
Wildfire Phoenix
Just wanting to inform those who may ask, my GE dryer only has knobs on it's control cluster because it's just a basic dryer, not some super fancy Samsung or LG dryer.
If you're a DIY on your auto repairs and want a good place to order parts you might want to check out https://www.rockauto.com/
They have excellent selects and great prices if you're ordering parts online and can wait for them.
  • Like 2
Your dryer timer knob may be cracked on the inside. So you think you're turning it to the desired cycle, but the timer doesn't turn because the knob is spinning on the shaft. So it's still in the off position, while the knob points to a cycle. Pull the knob straight out (don't wiggle it) and look inside where the hole is that goes on the timer shaft. Look for a crack. Get a new knob.
Edited by igloo
  • Like 2
Wildfire Phoenix
Unfortunately that was not the issue as the knob was not cracked.  Thank you for your suggestion though.
Wildfire Phoenix
All suggestions past this point in regards to my GE dryer are appreciated but not needed anymore because...
UNFORTUNATELY it shot smoke earlier today making any further repairs impossible since I assume EVERYTHING electrical component wise except the heating element are now fried 🙊🙊🙊
Still never got to find what the issue was and yes I'm still a tad on edge from the dam thing smoking up 😅😅😅😅😅
Sometimes it's better to call the repairman. I'm glad you didn't get zapped.
Wildfire Phoenix
I had the breaker switch to the dryer switched off.
Immediately after I flipped the breaker switch labeled dryer on, the dryer sounded like it arc blasted itself and immediately smoked up... ☠️☠️
Luckily no dryer fire happened 😅😅😅
Wildfire Phoenix
At this pont it's just easier to replace it entirely, cause it could just smoke up or even fireball after repairs 😅😅   So for safety concerns I'm just gonna junk its electrical parts.
The metal bits I'll find something to use those for.
Wildfire Phoenix
Ironically I already used Rockauto for car parts 😅😅😅
