B22CT80SNS Bosch Door Seal
Hi: This refrigerator is a rebadged Whirlpool.  Purchased mine around 2014. My brother has the same fridge, but under the Jennair badge.  Bosch door seal part number is 00713448.  The door seals failed and I need two.  The refrigerator works fine.  Each part is approx $250 across various part sites.  If I could get the Whirlpool or other equivalent model numbers that match this Bosch, could I possibly find the part cheaper?  Spending $500+ or more on refrigerator door seals is ridiculous.  Looking for input on whether what I'm asking for is event feasible.  If anyone knows the Whirlpool or other non Bosch equivalent of this model, I can look around myself.  Any advance someone could give would be appreciated. Thank you all in advance.
  • Replies 4
  • andrewinnc
  • dwschnelli
  • rjtrowel
Get the model from your brother's JA. A freezer door gasket could be sourced from that, if you are sure. We can see that it is "Push-to-insert" into the gasket channel. Please get a measure, outside corners, to the nearest 1/8". The best picture on a grid looks like 18"w x 42"h, but that's a bit of guesswork. And you are using plural "seals", as if they are identical. I doubt that. Give us some help here, there is no BSH X WP cross reference that I know of, would love to find one!
Thank you.  In the Bosch schematic it shows both doors, and the part number is the same.  That's why I say they are the same.  I definitely need two as the seals have broken off on the inside of the right and left doors.  I'll get his model numberr and measurements this weekend.  Below is what I'm basing the seals being the same one on both sides....
https://www.bosch-home.com/us/supportdetail/product/B22CT80SNS/01?srsltid=AfmBOory-Oie_OOa6qvXcYPJXJ2qB4ahTrjaZAPwLX3NzpNWy_-uaQ9u#/Tabs=section-spareparts/
I'm in the same boat, needing to replace the Bosch door seal (PN 00713448 - $250 each)
I would be interested in hearing if the Jennair door seals (or others) are compatible with the Bosch
  • 1 month later...
andrewinnc
Finally got hold of the Jennair model number for the Jennair equivalent for my Bosch refrigerator.  I haven't priced out the JA seal so I don't know if it is any cheaper.  I still stand by that my brother's 5 year old Jennair is the same as my Bosch from 10 years ago.  JFC2290REM00. Any suggestions you can think of (like maybe the Whirlpool equlvalent model #) would be appreciated.  Thanks.
