Service manual request (F3 error code Kenmore)
Manufacturer: Kenmore
Type of Appliance: Range
Model Number: 790.90153400
Problem Statement (State what is the appliance doing that it should not be doing, and what it's not doing that it should be doing.): F3 error code when the oven is on.
What diagnostics have you already done?: Service manual is needed.
Hello everyone.
I need a service manual for a Kenmore range that I’m looking at. F3 error code shows up when the oven is on.
I have moved this topic to the manual requests forum -- that's the correct place to post topics like this.
In any case, your model uses this tech sheet:
