Trying to research on how to remove GE microwave/oven unit model jkp62g0k3.  Did the normal Google search and came up empty.  Lots of results with parts but couldn't see anything about an manual or instructions of installation.  It's an old model (1991 or so) and was thinking of removing it and replacing it with the same 27" cutout newer unit.  Any suggestions would be greatly appriciated.
  • Pablos
  • Budget Appliance Repair
Not going to be an easy or neat job - this microwave oven is integrated with the lower oven as a combo microwave oven/regular oven combo unit.
Not sure what would be involved - if the microwave slides out after you remove the chrome trim ring around the microwave or if you have to pull the oven out of the wall and remove the side/top/back panels to access.
Thanks, I was hoping to read up on any guideness prior to taking a go at it.  I might just have to have bite the bullit and have the store installer perform the swap.  Thanks again for your input though.
