Manufacturer: Bosch
Type of Appliance: FDBM Refrigerator
Model Number: B26FT70SNS/02
I found a service manual for a B26FT70SNS but I can't make sense of the thermistor readings and error codes when running through them on the display. I can get into diagnostics like manual says. Error codes or display for sensor readings do not match what tech manual says. Checking to see if I have the right manual. Maybe someone can help me out. Could be too I just don't know how to decipher Bosch's manuals.
Here's the schematic for the /02 version.
Very Samsungesque. Maybe Hisensesque.
Can confirm this is the correct manual for your model/revision:
As Brother @vee8powersaid, for technical help interpreting and applying the information in the manual, start a new topic in the repair forum.
Thanks for confirming the tech manual!
