Manufacturer: GE
Type of Appliance: Front load washer
Model Number: GFW850SSN2WW
Serial Number (optional): FT323051N
Problem Statement (State what is the appliance doing that it should not be doing, and what it's not doing that it should be doing.): Requesting a tech sheet on this washer not sure if in right post I tried to search for it.
What diagnostics have you already done?: None
I have moved this topic to the correct forum. In the future, please post manual requests in the Manual Requests forum. That will ensure that you get help as quickly as possible.
Sorry
Uses the same tech sheet as these models:
@Blake30 you should be able to use these service manuals also:
