Kitchenaid freezer stopped making ice and a repair tech came out and replaced the ice maker.  Still no ice.  The water dispenser works fine.  Also, the ice maker optic control boards were replaced.  Anyone have a step by step procedure that I can use to diagnose this?  I suspect it might be the water supply valve but did not want to keep throwing parts at it like the previous tech did.  Thanks
  • 2 weeks later...
  • Nathaniel Peterson
  • dfphoto
  • lou123
check and see if the water reservoir is frozen
Pull out the ice maker and see if the in line fuse has continuity with it unplugged. If they didn't replace the wiring harness that could be bad and you'd need a new wiring harness to the ice maker.
Check your model number because it's not pulling up anything. All I can tell is it's a built in
