Kenmore Upright Freezer Model 253.22042410 - Identifying Clips
BillHammer
I was cleaning some ice off the bottom of my freezer (which probably shouldn't have been there) and scraping with a plastic putty knife. Over time, I found 2 of these clips on the bottom. See pics. What are they? Where do they go?
Also - big ice dam in the opening that goes across the inside of the freezer compartment at the bottom of the back wall. What is the easiest way to remove it without turning the unit off and waiting for a melt? I need the freezer to keep food frozen. And, do I need to get to the drain line? Is it in the back?
-Bill
  • Replies 1
  • BillHammer
  • Nathaniel Peterson
Posted Images
You can use a steamer and thaw the ice. As far as the clips I don't work on Kenmore so I have no clue, probably something that pushed off or broke because of the expanding ice. After steaming out the ice if you can get to the drain you can try using a zip tie or hot water to clear the drain. May have to get to the back of the refrigerator to manually clear anything from drain tube
