I have a KitchenAid KGSC308LSS0 range with a dead display. Previously it did work but constantly would give probe messages and sometimes it would even go into a reboot loop. I swapped control board with a replacement and it powered up briefly and displayed  F1E3 but then it completely shut down. Tried extended power cycling from breaker to no avail, and checked all fuses under the control panel and they are fine. Fuse on left has 120V in and out, and high limit fuse on the right is open which is correct from my research. Looking to see of control board is getting correct voltage from power boarddown below but cannot find service manual for my model. Anyone able to help?
  • Replies 6
  • Nathaniel Peterson
    4
  • johnnmax
Anyone??? I know that service manual is on this site. Was hoping someone could at least look at it and give a little help please 😁
  • 4 weeks later...
johnnmax
Well thanks for nothing people. Not a single ounce of help here. I only posted here because this site seems to be the only place online that has the service manual for my range. And since I could not get access to the file I was aksed to join and make a post looking for help and "surely someone would help me". But I guess not. All this for a 25 year old range where parts are scarce enough and a simple wiring diagram was all that was needed. Thanks to the "Pros" who could have lent a helping hand or even been nice enough to send a page of the manual.
Sorry, we're all too busy fixing this new junk that's out there and don't really pay attention to the diy portion like years past. As far as manuals per service agreements we can't give those out anymore like years past because the companies frown on that sorta thing. There should be a manual on the range attached to the rear control panel cover or on a sticker if it's that old.
Your error code says it's a jumper mismatch and depending if you have a hidden bake element depends on where the jumpers are supposed to go to.p3-1 to p3-5 red jumper wire for exposed bake element w/o top light model
P3-1 to p3-3 black for hidden bake element w/o top light model
No jumper for hidden bake element w/top light model
Now you have to let me know if you have a convection model or non convection model because you have to do some button presses to verify everything's working correctly.
Plus you can send your control board to CoreCentric and they can repair you board with a two year warranty. You might have to send all the boards in. Check their website to verify.
