BillD73
Hi folks.  The dryer did a load and a few minutes later would  not start for the next load. Dryer turns on allows you to pick a cycle, but when you push the start button, the drying light flashes but it does not start. I tried an LG reset, didnt work. Jumpered the door switch but didn't start when I tested for voltage across the jumper, I got nothing, so, I removed thee jumper and put the probes of my Klein MM directly into the plug I got voltage. I checked the switch and it tests ok for continuity when the button is depressed. I disassembled the machine further and checked the thermal fuse and it tested correctly for continuity. I checked incoming power, and got 120v from black or red to white, and 240v black to red. It would seem that the two most likely defects are not the problem. Not sure where to go from here. I printed the schematic so it was big enough to read, but, it doesn't show the sequence of events in the start up. Any thoughts are much appreciated. Thanks.
  • Replies 6
  • BillD73
    5
  • Budget Appliance Repair
  • CurlyThePony
What fuse did you test? There is one on the blower and one on the element. I would also check the cycling thermostat possibly the switch by the tensioner pulley.
inspect/test the control board
Edited by CurlyThePony
BillD73
Thanks for the reply. I checked the one on the element. I was thinking that I would proceed to the tensioner switch. I wasn't aware there was one on the blower. I will check the schematic again to locate that. Thanks for that. Would I be correct in assuming the blower needs to run before the heat comes on? I am not sure how to test the cycling thermostat. If this is the one on the element, it shows continuity. As far as the board goes, I am not sure how to check that. If it is in the board, the cost of a new one may negate the the logic of repairing the dryer. Again, thanks for the reply; it is very helpful
BillD73
Not sure why it says solved, as I am no where near finding the problem. However, I just tested the thermistor and while it shows resistance there is no continuity. Is it possible that this is the culprit?
BillD73
Last post. Last question. The diagnostic showed a faulty temp control. I tested for resistance and continuity. No continuity. Bought new part get same error. New part read same resistance and no continuity.. There is a very quiet click coming from control board when start switch is pushed. I assume it is a start relay. Any further thoughts would be appreciated before I go out and buy a new one. Thanks
That because the CONTINUITY setting on any meter is just looking for a very low resistance, (usually something under 50 Ohms).
The resistance on most thermistors are in the 1000's of OHMS rating so will show nothing on the CONTINUITY setting - also have to have the OHMS setting on your meter set to the correct high enough range to read the resistance of the thermistor correctly, (if you have the OHMS setting on your meter set to the 1000 OMS setting you will still see an OPEN reading on the themistor or at least a very low number 0.???? if the normal range of the thermistor is in the 10,000 OHMS).
BillD73
Thanks for the reply. I am a little out of my depth here. So, I am getting the same resistance reading from both units using my cheap analog meter and my Klein digital meter. I am new to the Klein meter so it took a few tries and videos to get it going. So, I guess my question is if I cant get continuity, is the thermistor faulty? Is it likely that the problem is on the board, since I am still getting the temp sensor fault using the Smart Diagnosis? Thanks.
