6 light washer stops spinning and lid lock light flashes
Lyricalsalvation444
When I put the 6 light washer into manual test mode (RTW4641BQ1 and WTW4800XQ4) I have two washers right now with this issue. When I select spin the actuator shifts over and the tub will start to spin but very shortly after (2-3 seconds) will stop and the green lights go off and the lid lock light flashes. Capacitor tests good, gear case is quiet, shifter seems to be working properly and splutch is not stuck or damaged either. Any ideas? I've ran into this several times and they've all done the exact same thing. Soon as the tub starts to ramp up in spin mode it stops and flashes lid lock light. Codes are F7E1, F1E1, and F7E7
  • Replies 0
  • Lyricalsalvation444
