Click here to take the quiz.
GE Profile free standing stove - Display flashes between bake & prob
Carpediem
Model: JB968S0H4SS
Display flashes between bake & probe
Can only use bake function with temp probe in place.
Can't broil or do oven self-cleaning.
I've turn stove circuit bracer off over night, but stove continues to not function.
:yikes:
  • Replies 5
Unplug the range and locate the tech sheet, it'll either be inside the control panel or down in the pots drawer you'll need to pull the pots drawer out all the way). Post, email or fax the tech sheet, 775-416-4449-- we'll need to look at that schematic to piece together a troubleshooting "strategery."
I got your latest fax of the schematic but the part depicting the meat probe is still a little muddy. The attached picture shows it as clear as I can get it. Are there any lines or notes not appearing in the picture that do appear on the original?
Sending scan of tech sheet with probe. Is this image any better?
Attached image doen't look to good, so I'm sending tech sheet in Word doc attached to email.
That's no better. Ok, different strategy, we'll get to the answer through the side door.
Page 6 of your tech sheet has a keypad test. Do that. Also, verify all control voltages to the ERC (see table on the same page).
If both those check out good, that only leaves the ERC as the culprit. Here's the part link: http://www.repairclinic.com/referral.asp?R=154&N=1086202
