JennAir JES9800AAW Dual Burner Outer Element Stuck on High - Infinite Switch Replacement Help Needed!
Optimizer
Hi everyone,
I'm hoping someone with experience replacing infinite switches on JennAir electric ranges can help me out. I'm having an issue with one of my dual burners on my JennAir electric range, model JES9800AAW (serial number starts with 17).
The problem is with the outer element of one of the dual burners. As soon as I turn the control knob for that burner to any setting above the "off" position (even the lowest setting intended for just the outer element), the outer burner immediately goes to full power (100%). It doesn't allow for any lower heat settings on the outer element. The inner element of the dual burner seems to be working correctly.
I've identified the likely culprit as the infinite switch for this burner. The original switch is blue and has the part number 7403P670-60.
When I tried to order a replacement, the part distributors are consistently giving me part number 7403P831-60. However, this new switch is significantly different from the original:
 * Color: The new switch is tan/beige, while the original is blue.
 * Pin Labels: The labels for the pins are different. The original (H1,H2,L1,L2) seemed more straightforward and matched my range wiring diagram.. The new one has labels like S1, S2, P1, and P2.
 * Wiring Diagram & Instructions: The new switch came with a wiring diagram that suggests I need to split the incoming red wires and add a jumper wire. This was not the case with the original switch's wiring.
 * Overall Style: The new switch just looks like a different design altogether.
I followed the wiring diagram that came with the new 7403P831-60 switch. It instructed me to split the incoming red wires and connect them to specific terminals (I believe P1 and "2"), and it showed a jumper wire connecting two other terminals (P1 and P2). The diagram also showed that S2 goes to the indicator light.
After installing the new switch according to the provided diagram, the burner now doesn't work at all.
I'm clearly missing something or have made a mistake in the wiring. The labels S1, S2, P1, and P2 on the new switch don't intuitively tell me how to connect it to a dual burner setup like my original.
Has anyone else encountered this issue of a seemingly incompatible replacement infinite switch for a JennAir dual burner? Does anyone have experience wiring the 7403P831-60 (or a similar style) to a dual burner where the original was a blue switch like 7403P670-60?
Any guidance or advice on how to properly connect this new switch would be greatly appreciated!
  • Replies 0
  • Optimizer
