Fritz
Usually points to the Hall Effect fan (00440604) on top of the oven.
Replaced that and still get F34.  I'm thinking the control board, unless it's the thermal fuse (00414633).
Are there likely suspects on the control board?  All the caps look healthy as do the smaller resistors and diodes etc.
Is there a particular relay that might be susprect?
Fritz
  • 2 weeks later...
  • Fritz
Checked for continuity on that thermal fuse button as well as the wiring that was easily traceable.  Nothing was obvious wrong or damaged.
I did give a little whack to K4 on the relay board as that is apparently the relay that throws the F34 error.
I also removed the display frame and examined the PCB that goes with it.  The caps all looked good though there was a fair amount of dirt on the PCB in general.
Of course reassembled, nothing had changed. Wondering if the display pcb could possibly throw the F34 error.  Seems unlikely, but appliance is not my wheelhouse.
as we said, checking all possibilities.
swapped out relay control board.  N/C.
the only wires I haven't viewed are the connects to the heating elements.
any possibility it could be the sensor in the upper right corner of the oven ? 00425301
