My Whirlpool Cabrio washer randomly starts to drain. I’ve had the washer for 3 weeks, came with the house, and twice now while not in use, no lights on control panel, no water in the tub it starts draining. It drains for about 60-90 seconds, stops for 30 seconds and then drains again for another 60-90 seconds then stops. Is this normal? Is this the way this washers works?
You may have gookus(technical term for nasty, unwanted blockage) in the pressure switch hose, or the air dome in the tub.  If that doesn't help, it's the control board. Disassembly  will be something like this:
I
If you're handy and tech oriented flip the machine and look for the tech sheet or it might be inside the console look at youtube to find out how
then run diagnostic or calibrate it...
