Dcrypted
My front load washer recently stopped working due to a power-ing issue. I replaced the main board and it started working again however it seems to be skipping the final spin cycle. If you run a rinse and spin cycle it will skip the last 9-10 minutes and leave the clothes really wet.
I have confirmed the washer is spinning and the pump is working to drain. I have also confirmed it is level, and re-calibrated (Hold Temp & Delay End at the same time until the screen says C6, then press Start.).
Also there are no codes or anything else but it does appear to related to this board swap (DC92-01849A).
Not sure why its skipping this part of the cycle (not just on rinse and spin).....Any ideas?
  • Replies 1
  • Dcrypted
Dcrypted
Anyone ever seen this type of issue with Samsungs?
