Bosch shu3030 Dishwasher
robertsultan
  Previously this unit was guilty of the shorted wires at the junction where the house power connected to the dishwasher.  I have checked that and all looks fine.  Is there a dianogstic to follow to trouble shoot this?
rb
  • Replies 14
Umm, you hadn't got the wires shorted, but one or more nuts had evaporated and the wiring was actually open...
To clarify things, the DW refuses from doing anything again, but the wiring at J-box is fine?
Yes, the wiring is fine and the machine worked well for 3 weeks.  Now it will fill up and then stop running.
Robert, did you get the service manual and wiring diagram for this dishwasher from your last repair?  If not, lemme know.  You're gonna use them to help you check for voltage going to the wash motor.
No,  I did not get those.  I could easily see locate that last issue. Where can I download those? Thank you.
They're on the Xdrive.  Look in the Bosch folder.  There's a manual titled something like, "Bosch DW Training Manual."
O wise one... How do I get to the xdrive?
You were sent an access link when you subscribed to Live Help.  How long ago did you subscribe?
I re-sent another access link to your email.  Let me know if you don't get it.
I have not yet received the link.  I did check my 'junk' mail folder too.  Thanks
Just sent another one.  If you still don't get that one, then there's either something wring with GlitchDrive or we can try another email address.  You can PM me an alternate email address if you need to go that route.
I have received the email... I set up an xdrive account and I can't see the spoon... I mean a shared folder.  All I see is the stock stuff.  Guide me please...
no such model as shu3030 / need more input or the serial#no
the model would look something like shu3032uc/01
[align=left]1M[/align]
[align=left]1M 1M[/align]
[align=left]F[/align]
[align=left]4[/align]
[align=left]1 2 3 4 5 6 7 8 9 10 11 12 13[/align]
[align=left]2 1[/align]
[align=left]2 4[/align]
[align=left]4 3[/align]
[align=left]1[/align]
[align=left]u2[/align]
[align=left]m2[/align]
[align=left]b a[/align]
[align=left]s2[/align]
[align=left]e0[/align]
[align=left]N[/align]
[align=left]L1 a1[/align]
[align=left]f1[/align]
[align=left]h1[/align]
[align=left]current path[/align]
[align=left]Symbol Key[/align]
[align=left]a1 ON/OFF SWITCH 2[/align]
[align=left]e0 DOOR SWITCH 3[/align]
[align=left]A2 ACTUATOR (Dispenser) 9[/align]
[align=left]e6 FLOAT SWITCH 7[/align]
[align=left]e5 FLOW SWITCH 11[/align]
[align=left]f3 THERMOSTAT 135°F 8[/align]
[align=left]f1 WATER LEVEL SWITCH 5[/align]
[align=left]f4 THERMOSTAT 149°F 6[/align]
[align=left]HIGH TEMPERATURE b1[/align]
[align=left]REGULAR TEMPERATURE none[/align]
[align=left]RINSE & HOLD b3[/align]
[align=left]f5 HIGH LIMIT 185°F 11[/align]
[align=left]h1 ON/OFF LAMP 4[/align]
[align=left]m1 TIMER MOTOR 12[/align]
[align=left]m2 CIRCULATION MOTOR 13[/align]
[align=left]m3 DRAIN MOTOR 10[/align]
[align=left]r1 HEATING ELEMENT 11[/align]
[align=left]s2 WATER SOLENOID 5[/align]
[align=left]u– TIMER CONTACTS –[/align]
[align=left]Selector Switch Contacts[/align]
[align=left]L[/align]
[align=left]permanent split[/align]
[align=left]capacitor motor (m2)[/align]
[align=left]u6[/align]
[align=left]m3 m1[/align]
[align=left]u4[/align]
[align=left]e5[/align]
[align=left]185°F[/align]
[align=left]f5[/align]
[align=left]r1[/align]
[align=left]e6[/align]
[align=left]2[/align]
[align=left]u5[/align]
[align=left]a b[/align]
[align=left]149°F[/align]
[align=left]f4[/align]
[align=left]135°F[/align]
[align=left]f3[/align]
[align=left]b1[/align]
[align=left]b3[/align]
[align=left]5[/align]
[align=left]u3[/align]
[align=left]A2 PTC[/align]
[align=left]SHU 303X/313X[/align]
[align=left]NOTE: Use timer to select wash[/align]
[align=left]program and selector switch to[/align]
[align=left]select water temperature.[/align]
[align=left]To locate each part, match current[/align]
[align=left]path from this table with current path[/align]
[align=left]along bottom of circuit diagram above.[/align]
[align=left]HINT: Float switch e6 switches from terminal 2 to 4 only if[/align]
[align=left]dishwasher has overfilled or water has flooded the base.[/align]
[align=left]HINT: Thermostats f3 & f4 with timer[/align]
[align=left]contacts 3a & 5b (during heating/drying),[/align]
[align=left]timer contact 4a (during rinsing), water level[/align]
[align=left]switch f1 (after water has filled) and timer[/align]
[align=left]contact 6a all advance timer motor m1.[/align]
[align=left]HINT: Diagram[/align]
[align=left]shows circuit at[/align]
[align=left]“Regular[/align]
[align=left]Temperature”[/align]
[align=left]setting with[/align]
[align=left]power off. Timer[/align]
[align=left]contacts (u2-u6)[/align]
[align=left]change position[/align]
[align=left](to “a” or “b”)[/align]
[align=left]according to[/align]
[align=left]timing chart[/align]
[align=left](Diagram) #64.[/align]
[align=left]At “High[/align]
[align=left]setting, contact[/align]
[align=left]“b1” opens to[/align]
[align=left]cut out[/align]
[align=left]thermostat f3[/align]
[align=left]allowing[/align]
[align=left]thermostat f4 to[/align]
[align=left]operate. At[/align]
[align=left]“Rinse & Hold”[/align]
[align=left]“b3” switches[/align]
[align=left]from terminal 3[/align]
[align=left]to 4, bypassing[/align]
[align=left]thermostats f3 &[/align]
[align=left]f4 and dispenser[/align]
[align=left]actuator A2.[/align]
[align=left]HINT: Flow[/align]
[align=left]switch e5[/align]
[align=left]switches[/align]
[align=left]from[/align]
[align=left]terminal 2[/align]
[align=left]to 4 when[/align]
[align=left]water is[/align]
[align=left]circulating,[/align]
[align=left]the heater[/align]
[align=left]to work.[/align]
[align=left]5602034902[/align]
SHU303x-313x-ckt-wrg.txt
