Frigidaire stacked washer & Dryer.
Lid lock solenoid has 105ohms across the solenoid and checks out as OKAY.
I am getting 120v at the "L" and at the "lock input" terminals at the board, with no lock plugged in. I was expecting 120v at the "L" but the lid lock should be nothing until the solenoid is energized and closes the switch to send 120v to this terminal.
Washing machine won't start and the lid is not locking after I press the cycle selector/start dial.
  • kerry H
  • MrApplianceMatt
Electrolux Frigidaire
#FFLE3911QWD
Posted (edited)
What pins are you checking? If you're checking between 2 and 1 or 2 and 3 in connector J13 the you're going to see 120 VAC because J13-2 is Line to the lock. Try unplugging the lock connector at the board and checking for continuity between 2 and 3 in the harness connector with the lid closed. The lock mechanism is a high failure part.
Edited by MrApplianceMatt
