New Appliance Service Manual added: Whirlpool Top Load Washer and Stacked Laundry Service Pointer - F3E1 Pressure Sensor Error or Drain Pump Running Continuously S Code: S153EB
View File
Problem: F3E1 error code (pressure system fault) or drain pump continuously running.
PUB W11766193 Rev C
  • 1 month later...
I am in the midst of one of these. Bulletin says to calibrate the washer, then run automatic test. , but I don't see how to calibrate this model...
  • 2 months later...
Hello. Is there a way to have found this by looking for the model number? It is relevant for me, but didn’t pull when I searched. Happy to have found it now, just checking if I’m missing a search technique. Or how others would have found this during diagnosis.
thanks!
Edited by Daniel P
thanks!
Looks like we hadn't included the model numbers this bulletin applied to in the description. I added them, so it should show up in search now. Thanks for pointing it out!
Thank you! Just making sure I wasn’t missing a search function. Much appreciated.
