Whirlpool Gas Dryer Model WGD4815EW2 (2019) no heat/spin action, just noise
Is this worth fixing? Dryer only makes a "whrrring" noise (as if it's working normally) but does not spin or generate heat, no matter what setting I put it in. Appreciate any help.
  • Replies 4
  • njose17
  • citizenX
The attachment is just a sound recording of the sound it makes. Hopefully, it'll help in diagnosing the issue.
Posted (edited)
Sounds like the motor is running. Is the drum turning? Open the door, hold the door switch closed and start the dryer. The drum should be turning. If not, mostly likely cause would be a broken belt (#341241) or the belt idler popped out of position, or the belt drive pulley broke or came off of the motor shaft. Easy fix and certainly worth repairing if that's all it is.
Edited by citizenX
This may not be the exact dryer but it comes apart the same way.
Hi Brian. Thanks so much for the reply. Yes, the drum does not turn (I did as you instructed). I will open up the dryer and check on the belt and/or belt mechanism. Hopefully, it'll be one of these - the easiest one preferred 😆 - and I'll clean as well while I'm there. I'll keep you posted. ~Joey
