GE Dishwasher Training Bulletin TB11-20
Manufacturer: GE
Type of Appliance: Dishwasher
Model Number: GDT665SGN3WW
Looking for GE training bulletin TB11-20. This bulletin is referenced in the full service manual for dishwasher model GDT665SGN3WW regarding testing for error code 56. Please help. Thank you.
  • Captain Dunsel
  • Mesaman2124
Posted Images
Posted (edited)
@Mesaman2124 Not sure that TB11-20  service bulletin exit? I guess you have a Drain problem.I believe your model uses the same pressure sensor talk about in this old thread.Take a look!
Edited by Captain Dunsel
@Captain Dunsel Thank you, I will take a look. Yes, having a drain problem. It does not throw the error code until 40-50 minutes into a wash cycle, at the end of wash cycle before it goes into a post rinse, I've had to check the chart to say for certain but when that happens it resets the control and kicks you out of the cycle. The drain pump is working and it seems to be draining well but possibly just barely above the port for the pressure sensor. Based on the service manual, we'll be looking at drain hose with check valve and then drain pump?
