Kitchenaid refrigerator Model #KRFC300ESS01 compressor issue?
Kitchenaid refrigerator Model #KRFC300ESS01 not cooling. Put it in diagnostic mode and all fans & thermistors appear to be working. I'm pretty sure the start relay is also working, as it does appear that the compressor kicks on, but it's still not cooling. Is it possible that the compressor kicks on, but the issue is still with the start relay or associated capacitor? The only other thing I can think of is a refrigerant leak, and if that's the case it's not worth fixing, so thought I'd see if anyone here has any ideas.
Here is a video of the compressor that starts just as the refrigerator is plugged in. There is a click about 30 seconds in, but the compressor does not come on. FF to the ~1:50 mark and you'll hear the compressor finally kick in about 2 min after plug-in. As far as I can tell, it's not cycling on and off (I'm not hearing tell-tale clicks), but I really can't be sure. Does this sound like normal operation, or am I missing something? Does this sound like a compressor low on refrigerant? It appears that it *may* be cooling the freezer compartment from room temp (~72F) to about 67F, but can't cool beyond that. TIA
  • EITlongago
  • citizenX
Update: new start relay made no difference.  I'm out of ideas.  Guess it's time for a new fridge.
It's probably not starting right away because the control board has a delayed start feature to protect it from rapid starts during power outages and such. When the compressor does start, if all the fans are running (inside the freezer too) but the cold parts aren't getting cold then yeah it sounds like a sealed system issue (compressor, leak, restriction, etc. ).
