Frigidaire FRFG1723AV03 - Power Cycling and Cooling
Hi there, I have a Frigidaire FRFG1723AV03 that I am working on that is presenting some unique issues I haven't seen and was seeing if anyone has experienced this as well.
Customer's complaint was unit was cooling intermittently. I had the customer plug in the unit to make sure it was running before arrival and it was cooling on arrival. I verified that the compressor was running and we were getting proper temperatures in both compartments. I went into diagnostics and verified unit compressor starts, the damper opens and closes, evap had a good frost pattern while running and that the evap fan was running. The last left was the control and the inverter board. I reset the unit and heard it attempt to start but it failed this time. I waited a while before attempting again and the unit did turn back on and begin cooling which was confirmed with frost pattern. My original diagnosis was a failure in the inverter board and wanted to see if anyone had an issue like this as well. I am reaching out to get the inverter replaced again but thought it couldn't hurt to see what the community thought.
Thanks for any advice.
  • Replies 0
  • nik.tasc
