amana gas dryer # alg866saw
buschman
outlet at wall good, having trouble with schematic, doesn't make sense to me. thermostats good. getting 120 volts at blue and white wires at motor, when "PTS" button pushed.  motor ohms out o.k. ...having trouble trying to figure out timer testing. any help would probably bring a suds donation..... thanks
What seems to be the problem with the dryer...
hi pegi, it's dead. will not start. motor ohm'ed out good, power at outlets good,  power into dryer o.k.,  120 volts at blue and white wires at motor, when timer pushed in to start, am just confused as to timer terminals to test,schematic is so small, i can't read, have timer out of dryer. didn't want to bother anyone, so i looked at the laundry forum but coudn't find anything.. thanks, buschman
Not sure, but looks like white and Brown? (brn) go to common and start (4-5) according to this wiring diagram...
Dryer_Wiring.pdf
