    • 11 October 2025 02:00 PM Until 03:00 PM
      When: Saturday, October 11 @10:00 AM Eastern Time.
Manufacturer: Whirlpool
Type of Appliance: Dishwasher
Model Number: WDT730HAMZ1
I need the Whirlpool dishwasher WDT730HAMZ1 service manual.
  • Replies 4
  • d915byrd
  • Son of Samurai
Uses this tech sheet:
And this manual:
Thank you for the information. I have a question if you have time.  I had a Whirlpool WDT730HAMZ1 dishwasher not circulating water during test mode with what I thought was the circulation pump running.  I ohmed the diverter motor at the motor and it showed open.  I put a cheater cord on it and it turned. What is going on? I didn’t have the schematic you sent with me at the time.  I tried to do the math on scene for the correct ohms based on 120v 32 mA.   I was way off from the ohms shown on the schematic.  I tried doing the math again but I get higher ohms.  Based on the specs below, I get higher ohms then the schematic.  Where is my math going wrong with the ohms law chart?
Remember that motors and other loads that contain coils of wire (inductors) are non-ohmic. This means that you can't calculate their current or power output based on the resistance of their coils.
If you're not given the amperage spec for the motor, the only way to calculate it is if you're given a wattage spec. Ohms won't cut it.
Thank you.  Need to read over the lessons again
