Click here to take the quiz.
I turned the oven on, set a bake temperature, and started it. I immediately opened the door, saw a spark or a blue flash, and since then, the oven doesn't heat. Controls seem fine. Convection fan runs, but there's no heat. Broiler does not work.
Does this seem like something I might be able to troubleshoot and repair myself, or do I need to call Wolf authorized service for diagnosis and repair?
  • Replies 1
  • robnw
  • BrianG
I bet you have two issues. Relay board failed, specifically the double line break relay. A visual inspection of the back of the board usually shows the failure. Also, you probably need a new bake element unless it’s been replace recently. The oven floor is known to flex and damage the bake element. There’s an update element with metal supports.
