Pump leaking
Joe N
I'm back. The other day it was a worn out motor coupling. Got the part and put it on with no problem. Itworks fine, however the pump is now leaking. Is it possible that it maybe cracked or a seal gone bad. I did not remove it when I replaced the coupling. Any suggestions?
Yes, just replace your water pump.
That sounded like as fun job :yikes: ...whole lot easier to remove the pump than hoses....
