JennAir Range JGR8850ADW door hinge replacement
starpal
Hi,
I have removed the door and I can see that one hinge is broken.
How do I get access to remove the old one and replace with new? Do I remove from the front, or do I have to pull it away from the cabinets to get the side panel off?
Also, should I replace both sides?
Thanks!
Can you pull the drawer out and get to the hinges from the bottom? Otherwise you'll have to go in from the sides. If I have to replace one hinge I always replace the other.
It looks like I'll have to get in from the side panels.  Is there a way to find a manual for this range on the xdrive?  Sorry, I don't remember how to get into xdrive.
