Dryer door seal - TT18DKXRQ01
Tarheel Technician
What kind of glue do ya'll suggest to glue a dryer door gasket back to the door. The gasket doesn't appear to be damaged at all, but it just keeps falling off. Thanks for any info.
  • Replies 5
Probably just some sort of rubber adheasive/glue that is good for high heat...
Don't have nothin to do with nothin but your label caught me Dryer door seal-TT18dkxrq01 (this is a Estate top/bottom) refrigerator...........here is what Whirlpool sends for the seals
But here's a much better way to order the high-temp glue, much cheaper plus you get an extra part with it.
Order the new sytle Frigidaire/Electrolux upper glide/felt seal: 5303937180 CLICK HERE to see and/or order.
It's a little bit smaller tube of glue, but you don't really need much, one of these tubes will be enough to do around 5 or 6 of these seals.
I never have to purchase just the glue, always have left over tube from the above seal or the older style glide/seal with the plastic teflon glides.
I've even used this glue to repair torn refrig door gaskets, it's a really good strong holding glue.
Thanks, Poobah. My bad. Was looking at the wrong piece of paper when I was typing that one!!
Thats aw-ight I was just being a smart alec anyway :D   ...... that glue Willie is talkin about is the same stuff and ya can save alittle moolah,always a plus
