SAMSUNG Refrigerator Model #RS267LASH
John E. Hoagland
Iam looking for service information on the subject regrigerator.  Any help will be greatly appreciated.  Thank you.  John
  • Replies 6
Konnichiwa, John.  I found several bulletins out in this fridge.  Haven't found the Job Aid... yet.  What problem are you working on?
The regrigerator is not defrosting.  I would like to know how to initiate the defrost cycle or how to do a continuity check on the heater without removing the freezer back panel.  Thanx.  John
Found the service manual and uploaded it to the Xdrive. For your convenience, you can download it directly here.
Known problems with these defrost heaters failing and you really...really....really....do NOT want this to be so....cannot get just the defrost heater, have to replace the evaperator ,  ref. # 11, that comes with the heater installed, well we can hope....the dude that thought this design up sure needs to be boiled in oil....:?
Thats the craziest thing I've NEVER seen.....I will have to remember that just in case I ever do run into one..thanx Pegi
You are welcome, I would not have a Samsung ref. and we will not work on them either....just too over-engineered....these sort of make the profiles and articas look normal...:P
