Maytag SAV405dbww
fixit guy
I got hold of me a sav405dbww Maytag that walks across the room when there is a small imbalance.  All seven suspension springs are attached and there are no white dust from the snubber.  When clothes are distributed evenly it runs smooth.  Any ideas?
Looking down at the top panel, try rocking the washer along the diagonals. If you get any play, any at all, the washer will walk in spin.
Also, found the attached tech bulletin that may apply to your problem
TDL-0061-B.pdf
Thanks for the reply.  This model number is real close to the above service bulletin . I will check it out.
Thanks again........
