Kenmore E-Dryer Model 110.64994300
megadan66
If you could help me out with a tech sheet and a little info please.Alright said dryer  motor only runs with start button pressed in.I've run into this before,used the tech sheet before and diagnosed it to the control board.Well this frigin' dryer had no tech sheet (only 2 years old.Where's the damn tech sheet),so like a good parts changin' monkey with a customer who wanted it fixed yesterday I bought a board(didn't have to order it this time,they must be going a lot).So it's not the board !@#$%^&*.After looking at the tech sheet on another forum I think it could be the motor relay ???Thanx for your help .......Dan The Appliace Man  AKA Mega-Dan
First thing to suspect would be the motor relay, to test just exchange it with the heat relay to see if the dryer will stay running...did you look in the console for the tech sheet???
You can borrow my TECH SHEET if you promise to return it.....
fixed this problem three times before,always was the control board,maybe the next three times it'll be the motor relay.Didn't even know it was there until this dryer.lolThanx for the info.I'm almost sure that's what it is and there cheap enough just to take one....Thanx again Mega-dan
