Amana Wahser squeeking
atcherservice
atcherservice
I have an amana m#lwm833w that when in aggitate therre is a slight squeek and then gets louder in the cycle. Should I change out the bearing housing or is it something else.
Ken
  • Replies 1
Could very well be dry brake pads.  They are supposed to be lubed with poly lube or silicone grease.  When they get dry, you get a rythmic squeak with each agitate stroke.  If you run the pulley up, you can lube them with a Q-tip.
