whirlpool range #RBS305PDQ6
Wingnuts45
Have a range that was put into self clean mode...it cleaned then Range wouldnt BAKE or broil.....I replaced the thermal fuse....it works now but when turned off both bake and broil elements are still on.....Could this be that both elements got fried when self cleaned or should i just go ahead and replace the microcomputer....?TIA
  • Replies 4
Here's the tech sheet for this oven.  I'd start by killing power, puling one wire off each element, reapplying power and then measure the voltage at each side of the element.  Looks like one side is always hot, tied into L2.  I'll bet my butylene sphincter that you're getting voltage on the L1 side.
I had one with the same symptoms.  Replaced ERC and all was well.
This unit is a built in and who ever wired it up didnt give enough slack to pull it out to get to the back with out disconnecting the power...So i disconnected power to it and tested the thermal, replaced it....Didnt want to eat a ERCif i  didnt have too.(Parts Monkey hehe)..No tec sheet  either....Thanks
The Samurai posted the link to the tech sheet for your unit...
