Kenmore Error Codes help
atcherservice
atcherservice
I have a Kenmore stove (665.75014101)with the broiler not working on a gas range(igniter fine). At first there were no error codes, we proceeded to install new control board. After installation the unit flashed an E1 and F2 error code. In the hopes of not being a parts changer we want to change out the temp sensor. I have a sneaking suspicion that the board might be bad. Any ideas?????
Sensors are easy enough to check that it awwta be checked regardless of what the fault code means:
http://fixitnow.com/2003/02/appliance-tip-of-day-oven-temperature.htm
Also, disconnect power from the range for a couple of minutes and then power it up again.
This range is built by Whirlpool. Here's a reference document of fault codes for all Whirlpool and Kitchenaid ranges.
  • 2 weeks later...
sorry i`m late had to replace my H.D. and add more memory , so i can address these 665/ whirlpool questions  E1-F2 stuck touch pad  common problem with the 665 models and the 364 g.e. models (911.) but the erroe code is f7
