ge microwave JKP85BOA3BB
texasred
Got a m/w that the turntable will not turn and no heat. Replaced turntable motor and have checked mag still will not go. Customer stated she came in one day and the unit was running and table turning on its own. Then it quit completely. Any ideas as to what to do next?
  • Replies 7
I woud say item # 16b which is the cntrol is bad, it's the only thing that will make the machine come on by itself
Leadimage.asp?productTypeID=0124500&brandID=0432&modelDesc=ELECTRIC%20RANGE&modelNumber=JKP85BA3BB&documentID=E2140892&documentTypeID=PLDM&documentClassCode=PV&titleType=MICROWAVE%20CONTROL%20PANEL%20%26%20DOOR&titleID=00003&
I replaced the control and still no turntable. Is their a relay that activates the turntable motor? From the diagram I have could not find one?
you replaced the control and the turn table motor?
I cant pull up a diagram, but as far as I know there is no relay for the turn table motor. Have you checked your door switch assembly?
Going to tomorrow. It was next. Today is the day of some rest (I hope) appreciate the info. Dont work too hard this week. Be back manana to report.
The problem is solved. Someone had worked on this unit before and had wedged the bracket holding the door switches because they had stripped the screws holding the bracket, so when they closed the door monitor switch would not engage. When I checked the switches they checked good but did not see the wedge so when I removed the bracket and removed wedge found the problem just a larger screw solved problem.  One of those simple yet hair pulling diagnosis.  Thanks for the help!!
Glad you figured it out, I hate it when that happens :yikes:
Nice 'shootin', TR! :armed::cheers:
